Mk2 Ibiza 16V Hillclimb/Sprint car - 2014 Race Season begins!
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
I think they sent me mk3 ones. Despite me ordering mk2 ones, and waiting 4 weeks, and being charged £18 for delivery. Not happy one bit.
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Love it kev, tha was a cool car, great seats! To keep the windows flush with the outside line if the car, i have fitted them as per the original pop out windows, left the rubbers in place, cut three holes ans used the original mounting hardware. There is a bit of flexibility in the rear end of the window but thats ok as it can vent the cabin and stop the rear window blowing out if i have the drivers window down a bit when its hot.
Revo Kev
www.onlyrevo.com
Feb 24, 2003
1,488
www.onlyrevo.com
Memories:
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
very cool memories - that was such an awesome trip
might go back with the S4......
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
westallc
132
this car has been an inspiration so i have brought a mk2 ibiza 2.0 8v to turn into a track car
i have many questions for you if you can spare 5 mins at some point hat would be great
where did you get wings and bonnet from ??
and if you was to do this again wat would be your first mods ??
many thanks
clive
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Ta, yep we can have a chat at some point no probs. Doing this again.....well it depends what you need from the car. To begin with, my car was driven to trackdays, driven to nurburgring etc, so had to be useable on the road. As time has gone on, its got more and more race-like, and i wouldnt now want it as a road car, very noisy, lots of vibration etc etc. For what i want now, i would start with a bare shell, acid dipped, weld in cage, and nothing goes back on without a serious reason why. I may still do this at some point. So it depends what your needs are?
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Mental project here, continuing thinking in this thread to reduce capacity of 1.8T to 1400T for racing in <2000cc classes
http://www.seatcupra.net/forums/showthread.php?t=178266&page=3
Mk2 ibiza was fitted with highly acclaimed 1400 16V AFH engine (also used in Polo). Sorg (dissolved German tuner) had a turbo version of this up to 374hp.
Here's one from Greece fitted to a Mk2 ibiza showing 250ps as a kit
http://www.turboservice.gr/en/tuning.html
Other AFH turbo manifold available in Greece
http://www.boulekosdynamic.com/en/products/pollaples-exagwghs/VAG1416v#product
Apparently the big issue with this kind of power is what a lot of G40 Polo drivers eventually run in to - the weakness of the 085 gearbox.
There is some talk on the internet about fitting 020/02a boxes to these 'small blocks' but no substantial details. There is an adapter plate mentioned:
1.4 G60 Polo of Peter Nauman has 280PS so clearly they have worked out some method of transmitting bigger power
http://www.polotreter.de/technik.htm
Rumours are it may be with a highly costly 085 sequential conversion from Klaus Bernert
http://www.klaus-bernert.de/rennsport.shtm
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Ok - so some quite rare pics here of the fabled Sorg Motorsport modified 02a gearbox casing that enables an 02a to be bolted to a 1300/1400 small block engine. Its quite a lot of fabrication, and it needs to be spot on so they must have done all this with some kind of jig. Its predominantly 02a, but with the 085 starter housing grafted in, and some extra mounting points. To make this work you would use a G40 flywheel and then a custom 200mm clutch with a 02a centre spline and a modified cover to use the 02a release bearing. These have traditionally been used on high power G40 Polos where the engine needs tilting to maintain driveshaft angle, custom mounts, chassis leg cut and shut etc etc etc. Big bit of work. In an ibiza already fitted with an 02a, its a lot more simple as the box would stay put, and the new engine sited appropriately. Driveshafts would remain standard, but custom clutch would be required - £300 from Sachs or Helix.
But an even better idea has surfaced today.....[B)]...........:funk:.........
Details soon
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Guy wants £900 for it, empty gearbox casing, no mounts. Probably right as Sorg rumoured to have charged 1000 Euro-ish new when they were making them. Seems dear but there is a lot of exact work needed to do this so its probably fair. In custom fabrication, 1000 notes doesn't buy much. Thing is, it would do the job, and would make the project possible, but a mate has an alternative method available any time using a 10mm steel adapter plate. It will be more robust, use more standard parts, and enable me to use my existing 02a clutch setup (which I know works) rather than having to move to custom G40 parts. More details very soon.
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
I'd have thought the known quantity is better Rob?
for the amount of use the car gets per year there must be a limit as to what is reasonable?
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Interesting website - 'how many left' - tells you how many of a particular car are still running.
Mk2 Ibiza 1.8 16V GTI - as of Q42013, 4 licensed and 5 Sorn.
NINE left......only.
Staggering.
Who knows where they are?????
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
1.8 16V GTI - 4 licenced, 5 sorn (first sales 1996)
2.0 GTI - 45 licenced, 18 sorn (first sales 1996)
GTI - 13 licenced, 7 sorn (1st sales 1995)
GTI 16V - 120 licenced, 70 sorn (1st sales 1998)
GTI 16V Cuprasport - 19 licenced, 20 sorn (1st sales 1997)
GTI Cuprasport - 297 licenced, 98 sorn (1st sales 1997)
Cordoba 16V - 34 licenced, 3 sorn (1st sales 2000)
Cordoba GTI - 1 licenced, 0 sorn (1st sale 1996)
Cordoba SX - 58 licenced, 10 sorn (1st sale 1996)
Cordoba SX 16V - 55 licenced, 24 sorn (1st sale 1998)
Cordoba SX Cuprasport - 1 licenced, 0 sorn (1st sale 1998)
http://www.howmanyleft.co.uk/
