On all of the other cars I have had that have had CC they do the thing where 1 click up= 1MPH faster and 1 click down= 1MPH slower. the leon doesn't seem to do this and it is bugging me. Is it a VAG-COM thing or is that just the way it is.
Mines is 1mph too. I just do a quick press of the buttons (up or down)
Seems to work ok for me.
Alex
If I dab the buttons just once up or down the speed does not change, if I hold the faster button it goes faster till I release it and if I hold the slower button in it coasts for as long as I hold it.
When you guys get the 1MPH thing going on, how long do you dab the buttons for, just a quick flick or dab it for a second?
For example, on my old mk4 Ibiza if I did 10 quick dabs on the faster button the speed would go up by 10MPH, on the mk2 leon I do the same (10 quick dabs) and the speed goes up by about 1-2 MPH
Mine's the same as yours. If I hold the increase button then the speed increases, but not by a set amount. I just hold it up or down until I get to the speed I want, then release. I prefer it this way anyway, it's more predictable.
Press the upper part RES/+ of the rocker switch to increase the speed. The vehicle will continue to accelerate for as long as you keep the rocker switch pressed. When you release the switch, the speed is stored.
just a quick question on the topic, when you switch CC on and use it, should there be any indicator of that on the cluster? any light or anything?
don't think you do unless its for the bigger computer screen when you choose the bluetooth option...
yeah there is. i think its a green dial, could be wrong tho.
