should the mk3 ibiza cupra 1.8T master cylinder fit direct onto the mk2 ibiza brake servo? ive looked at part numbers and it suggests that the brake servos are the same part number, and as such the master cylinders should be interchangeable... (I know the pipe fittings are different but ive overcome this) my issue is that the master cylinder seems to be being compressed slightly when tightening it to the servo...
is this fine? im thinking that the little bit of compression will apply the brakes some what, and what is causing my issue of the brakes binding and then locking firm on (presumably when they get too hot they lock because they free themselves up when cooled down)
help please... its doing my nut in and i cant drive my car until its all fixed
the only thing i can see to do would be to get a spacer made around the 3 / 4mm that the master cylinder gets compressed and put that in between the master cylinder and the servo... i should have to do this though should i!?
Taaaaaa
Taaaaaa
