Hi all,
hoping to get some advice with the problems I'm having with my 2011 Mk2 Leon 1.6 TDI
The problems started a few days ago with no warning signs beforehand. Traveling on the motorway the other day when suddenly a plume of white smoke came out the exhaust and a considerable loss of power and a rough/rattly engine. AA came out, diagnosed that my turbo had gone and towed me home. I've since had the turbo replaced but the problem remains. The mechanic I used seems to think it could be down to a faulty injector.
The symptoms are:
White smoke under load/acceleration. No problems when redlining the revs or idling, no problems pootling along at 30-50mph on a straight road. But if I'm accelerating or going uphill the smoke comes out, with the smell of diesel, and the engine becomes a bit rough. There isn't any foam in the oil. The coolant level hasn't changed. I tried dumping a bottle of fuel injector cleaner in the tank, and the smoke eventually changed from a white to a blu-ish white smoke, which to me indicated that it is a problem relating to unburnt fuel, although I'm no mechanic.
I have got it booked in a VAG specialist in over a weeks time, but I'm looking at atleast £400 to diagnose/remove injectors/test injectors/refit injectors, before I've even bought any replacement injectors, and the injectors are £300ish a pop aswell. And I'm already down £500 for the replacement turbo. So if anybody here has any ideas or suggestions please let me know.
Many thanks
The symptoms are:
Many thanks
