1bar 2Bar 3Bar...............bang!!!!!
if you fold it back on its self so its kinked then cable tie it. that should work.
you just need to block it in some way
Sorry to hear the mbc didn't do the Job, I don't understand why. I can't see a turbo of that size not being able to flow more than 1.2 bar of boost.
How did the quality of drive change when you disconnected N75 valve and replaced with mbc, was it as smooth.
did you ever log N75 duty cycle? was it max'd at 100%? I cant remember
Jamie mine boosts to well beyond 1.4 BAR easily, I've seen 1.8 BAR when setting up the Apexi, so something is up and yes, be careful.
With the Apexi switched off, it boosts to 1 BAR as it has a 1 BAR actuator spring as standard. What DV do you have?
I have said this already but you dont seem to be really taking me seriously...there is no reason the N75 shouldnt be able to control your boost. I do not think boost control is your problem as I dont think the boost is there in the first place. N75/ebc or mbc only control the amount of boost. If it cannot make the boost in the first place its not there to control. No reason your N75 shouldnt be able to control it so if your still not getting the boost something else is your problem be it the map or hardware. And I still cant believe you havnt check your actuator unless P-torque did this and you havnt said.
What Bill originally suggested you did will just show if the turbo can actually produce more than the 1.2bar boost you are currently getting. Find out what your actuator pressure is. Did P-torque not check this before mapping? Currentlt I dont think your car can make over 1.2bar which has been shown with the mbc. Be warned though there is no guarantee any mbc or ebc will give you more boost than the map requests so if its not getting it originally theres no saying you will get it with an mbc or ebc fitted.
You dont have vag com, do you?
i cant remember now if you disconnected the N75 and logged boost?
whats your static boost from actuator only?
logging boost is block 115, timing pull 020, airflow 003, fueling 032/031
