Mk1 leon cupra door seals
Jan 18, 2023
Hi all, recently purchased a Leon cupra r mk1 and noticed that the drivers floor and passenger rear floor is damp. From doing research i believe this is down to the door seals? How do I go about fixing this? Any help appreciated.
MoToJoJo
823
653
Northants
It's one of a few options
1) The pollen filter housing
2) The relay panel
3) The door panels
Most likely is #3.
Lots of guides out there, just use butyl tape rather than silicone because you'll need to get access behind the panel again at some point and silicone is an absolute nightmare in that case
mty12345
3,907
538
bristol
Reactions: Nowonmai
smutts
373
188
Not hideously difficult, but is tedious.
If you do have to do the two square four inch holes in the front plenum, while you are there do the plastic screen wash pipes too.
Clear vinyl tube of various sizes, glue together beautifully with solvent glue used for plastic waste pipes.
Reactions: Nowonmai
