Mk 2 Leon DV Forge spacer..Question?
deann
125
Wolves
Hello all. Ordered the Forge DV spacer on Xmas eve. should arrive tuesday...
Is it as easy to fit as undoing the 3 screws putting the spacer imbetween the standard DV and doingthe screws back up...
I have read a few threads but they seam to be changing the DV at the same time..
Thanks guys.
deann
125
Wolves
Any one got any step by step pics?? Its due to arrive tomorrow. i cant belive it that simple.
Thank you Knight.... did you take any pics?
And are you still running yours with the standard DV? or have you upgraded?
deann
125
Wolves
Its just arrived by parcel force... -2 outside but i want to fit it after tea..
Which way does it face when fitting? As it cone shaped does it face to the left or right??
Any installation pics would help massively..
Thanks all.
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
i took mine off last year and floged iton as it got quite embarassing when driving slow, with it whooshing like hell, but it did sound good when hammering it.
reference fitting it, its not a hard job, just real awkward to do the bolts etc.
@robby71
basically its a spacer that sits between the factory DV and has holes in it so that when you DV releases pressure, it vents it to atmosphere instead of recirculating it back into the turbo. No performance gains to be had, just a whoosh everytime you come off the accelerator. My ITG does it now, but with the added bonus of only doing it when i bury the throttle and is ok when tootling around slow.
be aware the guy i sold it to had the new Revision D diverter valve, and the spacerwouldnt fit it
robby71
653
91
Yorkshire, UK
@robby71
Ah - cheaper than a ATA replacement :) I have a Baileys on my Focus ST and at low boost it chirps :( sounds ok at high boost though
deann
125
Wolves
Just to you guys now in -3 degress the Forge spacer is fitted and sounds SWEET!!!
sounds best 3rd to 4th
Great mod for £40..
Post some pics tomorrow in the light.
deann
125
Wolves
[:@]Ok guys i have a picture signature.. As you can see i have one 5 pics on my profile why cant i add more or even show the pics of my Forge spacer??? HELP
K1Shane
336bhp 319 lb/ft
Apr 17, 2010
730
Northfleet
Hi. Am going to be collecting my 58 plate Cupra K1 in 2 weeks time. I love the sound of a dv and am looking for a little advice on which to buy. Do I need a whole dump valve or will this spacer suffice? I don't want too loud a noise but enough to be heard outside. Also the flutter sound, can I get a straight answer. Is it achieved by getting an open end cone filter. Or is it down to a specific dv? Or is it a mix of both? Any help appreciated, thanks
Poverty
all you need is a forge spacer, the spacer gets louder the more boost you run. With a open cone it does get louder asell
K1Shane
336bhp 319 lb/ft
Apr 17, 2010
730
Northfleet
Jus re-read this and also a few other posts. I'm hearing a lot about the spacer not fitting because of a revision d piston or valve? Is there a way of knowing if I can fit it? It's a 58 plate k1
rikwandi
52
The Hague, Holland
According to the JKM website, the upgraded version is compatible with the forge spacer, part no. FMDV14T. Here is the link
But probably I'm wrong? :shrug:
Scot_jordan19
I was just wondering if you fitted the old FMDV14T for £43 and the upgraded FMDV14T for £45 ? Or just the upgraded one?
