right where to start i have a 03 lcr 210 , its had a missfire problem since i have owned it for 3 - 4 months the car starts fine from cold , it idles fine from cold , it idles fine right upto when it gets to normal operating temperature . It would start to get a lumpy / missfire at idle after either giving it 3-4 hard accelerations then left to idle or if its left idling untill the fans come on . when its driven whilst heating upto temperature its fine .when at temperature you can floor it 2-3 times and it behaves , however after this it then starts to missfire / judder under full boost .
right now the list of replaced parts and work done to try fix this problem
1. new maf
2 .new pipercross panel filter
3 . new coil packs
4 . new spark plugs
5 . new fuel filter
6 . new dumpvalve 007p
7. cleaned throttle body and reset with vag com
8 . n249 bypass
9 . checked all breather hoses and cleaned all , also replaced some and retighted clips
10 . redex fuel cleaner
11. insulating tape around coil pack wiring ( just incase)
12 . checked for exhaust leaks
also had vag com scans and i have NO error codes .also logged various blocks to which the lambda sensor says the engine is running lean .sooooooooo could my symtoms be a failing lambda ? would it fail for 4 months and produce no codes ? please help people i am at my wits end here
1. new maf
3 . new coil packs
4 . new spark plugs
5 . new fuel filter
8 . n249 bypass
