Mini ISO to RCA?
fozzie-foster
I have no idea lol....but if so i'll just cut out the back speakers and run my 6x9s through a second amp!
cupraNCS
90
Port Glasgow
Or could i run some extra speaker cable either side from this block (which is for my 6x9's) and conect 2 the high level input on my 2-chnl amp?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
doesnt the top connector break into 3 ?
i know the leon did cos i added headphone sockets on one once
cupraNCS
90
Port Glasgow
Yeh it breaks into 3 but when i replaced the yellow one withe the ISO to RCA connector when i turned on the ignition the aircon came on and all the functions for it wouldent work or show on the display:confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
have a look on icecavern.com there should be a pin out diagram there for you to check it out with
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
http://www.icecavern.com/forum/index.php?showtopic=112&hl=pinout
For the Leon Aura unit but may help ?
All viewed into connector on head unit
Section 1 - Not all of these are available on the Aura v4 (Headphone, Telephone, External Display)
1 Not Connected
2 Not Connected
3 Headphone Out GND
4 Headphone Out L
5 Headphone Out R
6 Switched (+12V when unit is on)
7 Telephone Audio In Signal
8 External Display Clock
9 External Display Data
10 External Display Enable
11 Remote ( Not sure of its function )
12 Telephone Audio In GND
13 CD Data In
14 CD Data Out
15 CD Clock
16 +A CD (Not sure of its function but related to CD changer)
17 Switched Power to CD
18 CD Audio In GND
19 CD Audio In L
20 CD Audio In R
Section 2 Speakers
1 RR+
2 RR-
3 FR+
4 FR-
5 FL+
6 FL-
7 RL+
8 RL-
Section 3 Power
1 Speed Sense Wire
2 Telephone mute - Active low - Take to 0V to mute
3 OBD Diagnostics
4 Switched Ignition +12V
5 Antenna control (+12V when unit is on)
6 Illumination
7 Permanent +12V
8 Ground 0V
cupraNCS
90
Port Glasgow
Well from looking at that the part i disconected to fit the ISO adaptor would take up numbers 1-6 and none of them seem to be anything to do with the climate control and its functions:confused:
