milltek non Resonated psi???
ljpacey
aka captin slow!!
Jan 19, 2009
161
hi guys i just fitted my new milltek non res and i gone from 11 psi on boost to 16psi then tail back to 9 ish should it be doin this??? anyone had same problam:confused:
techathy
^^ my name, my thought >>
Jul 9, 2009
115
Cambridge
If that's as spike when you floor it that's the sort of thing you'd expect when you lower the back pressure on the turbo. Because the turbo is spinning up quicker it's overshooting the target boost level more before getting pulled to the desired boost level.
ljpacey
aka captin slow!!
Jan 19, 2009
161
thank for that i gessed it would do that but not 5 psi :0 will it do any dammage or will it be ok??
