Mib2 navigation unit retrofit wrong part?
guyF20
7
Croatia
Hello, I am planning to do a mib1 to mib2 retrofit ony my 14fr and slowly getting the parts one by one but I recently ordered navigation unit with part number 5F0035824C with out much investigating about sat navs, also it was on the cheaper side on ebay (maybe for a reason) which has only one sd card slot and at some pictures on internet with same unit in other cars have seen in the menu that there is no option to use standard seat inbuilt navigation.
My question is will I be able to use navigation from sd card?
I plan to do alot traveling with this car and dont want to rely solely on android auto maps because in some European union countries internet is free but rest is not so it would be preferable to have the inbuilt sat nav option aswell.
Did i maybe bought the wrong one, since my mib1 unit has sd card navigation but has no android auto and apple car play which is why im planing to retrofit mib2 in the first place. Many thanks.
  • Sad
Reactions: andye1 and Walone
The unit you have bought does not have DAB or GPS, it’s not far from the worst MIB2 unit you could have chosen
Reactions: guyF20
guyF20
7
Croatia
Thats Bad. Wrong unit.
Which Region you Stay in Austria?
No I live in Croatia, damn I wish I did some better research before buying.
Wow :(
If somebody can post the correct navigation part numbers for mib2 would be appreciated so people dont make same mistakes as me as I believe there are many out there stuck on mib1 with 0 upgrade options :( Thanks for replies guys.
cairus
975
328
Since you need a patch to make everything work in your car, I would take a device with a maximum firmware of 04XX. Here you can do everything yourself relatively easily. Article number 5QA035858B
Reactions: guyF20
guyF20
7
Croatia
Thanks Il let people with more knowledge handle it once I get my hands on one.
