For those that like built in maps and have a European pre face lift Ateca Cupra where they all came with the Seat Plus / mib2 high entertainment system the map update has fallen out of the wood work early. You do need the life long FeC for it. Starts with 073 and finishes in EE.
Details. Works fine.
Further up that thread is how to get UK TMC back on these unit.
Note, I've re-edited the above since PCBBC implemented a method where you didn't need Obdeleven Pro / VCDS to change the traffic TMC code, they did that within the module. If you do have Obdeleven Pro / VCDS and you are taking the car abroad and want the RR solution, then use option a. Obviously...
www.seatcupra.net
