Magical lubricant
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
hello everyone
Just servicing my kompact dual port dv and it says to clean then apply turbosmart lubricant
Now i know turbosmart don’t have a magical formula so my question is what do they use?
They state don’t use viscous oils :confused:
Is is just wd40 lol
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
hello mate
Yeah i love it the noise is great :D well im having a couple probs now but i think it could be down to how I’ve serviced it :S a hell of allot louder than that mouse fart of the 007 and nope ive still got my standard smoothed box so it would be louder with a cone:p
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
i got some k+N airfilter grease i wonder if that would be ok ??
OO and by the way it did say dont use grease:confused:
Ronin225
4,652
22
Worcester
The idea of grease is to lubricate but still be sticky enough to adhere to where applied
If oil is used it would drain off or escape the system entirely leaving only a thin film
Without knowing exactly how this valve works it is difficult to advise, but you could try air line oil, its very thin
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
cool thanks mate any idea the best place to get any ? because ive looked for turbosmart stuff and it will cost a bit to get it from america
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Cooking oil would do as its not going to wreck your seals.
If your fussy get extra virgin olive oil, if not vegatable cooking oil would do.
I'm surproise that is says not to use grease as there are MANY types and as above oil will venetually disappear and leave your seals dry.
What service intervals do they suggest?
csd_19
2,279
28
Angus / Edinburgh
How about some Teflon bike lube? Finish Line do a "Dry Teflon Lube" which goes on wet (obviously!) but then dries to leave an teflon impregnated oil film. Been using that for years on the mountain bikes during the drier months as it works really well, also used it on my HKS SSQV to keep it lubed.
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
thanks mate half year intervals i never thought of cooking oil :p
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
good idea :happy:
AntneeUK
2 Wheels 2 Many
Mar 8, 2009
1,491
Nottinghamshire
Is is just wd40 lol
Don't know if you were being serious or not, but I really don't like the idea of using WD40 for any kind of lubrication outside of things like door-hinges. It's technically for displacing water (WD = Water Displacer). In comparative terms, it's not actually a very good lubricant. It is however very good at releasing seized bolts etc. If ever I was lubricating anything of high performance (like bike chains etc) I would always use a specialised lubricant
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Infact, looking at the instructions I'd say this is a specialist type lube.
If its quite wattery then its most likely:-
Mineral Seal Oil or Pale Spindle type base with a small amount of corrosion inhibitor, friction modifier and extreme pressure additive. It may even have a tacky additive to stop it from running off the components.
I'd get the proper stuff if I was you.
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
i think you could be rite not easy to get hold of this tho :headhurt:
