I had a trackday today and before I reached the venue the EPC, Traction control light and eventually the engine light went on
Got back home connected VAGCOM and got a load of errors which I've listed below. Can someone kindly help me with diagnosing the problems listed below.
Some info:
MAF is around 6 Months old and bought that from Eurocar parts. This problem initially started last night when I went to fuel the car. The EPC and TC light went on so I swapped the MAF sensor with one from my Octavia vRS. Everything was fine until when I reached the venue the lights on the dashboard lit up.
6 Faults Found:
17976 - Throttle Actuator (J338): Mechanical Failure
P1568 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
P1542 - 35-10 - - - Intermittent
Readiness: 0010 1100
Address 03: ABS Brakes
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 01048
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Some info:
6 Faults Found:
Coding: 0021505
Shop #: WSC 01048
1 Fault Found:
