MAF specified block not available
processpaul
103
Brighton
Hi,
I have a 2005 Seat Altea 1.9TDI. (VCDS version 908.1. genuine HEX-CAN cable )
I've lost some power of late, and think its a possible MAF issue. There are no fault codes, and MPG seems fine. Car feels slow to pull, just no oomph.
This is my first time logging so have logged groups 3,10, 11 all at once. I plan to do them separately soon.
The label file has no "MAF specified" measuring block, What should I log to find my boost issue?
Label file for my engine is:
03G 906 016 BKD
I Live in Brighton if anyone can assist with my logging:)
Thanks.
processpaul
103
Brighton
Ferryman
block 10 lists the following, no MAF Specifed signal will be logged by the look of this or am i mistaken.
010,0,Charge Pressure Control
010,1,Mass Air Flow,(actual),Specification (Idle): 180.0...300.0 mg/Str.\nSpecification (Full Load): 800.0...1100.0 mg/Str.
010,2,Atmospheric,Pressure,Specification: 900.0...1100.0 mbar
010,3,Boost Pressure,(actual),Specification (Idle): 900.0...1150.0 mbar\nSpecification (Full Load): 2000.0...2500.0 mbar
010,4,Accel. Pedal Pos.,Sensor 1 (G79),Specification (Idle): 0.0 %\nSpecification (Full Load): 100.0 %
