flooky
ok, i had a new maf from seat about 3 months ago and it's been fine uptill today....
today the weather here has been raining real bad and when driving on the motorway the car started jerking and not wanting to move forward...
managed to get the car off the M5 and pull over.. when ever i gave the car light or heaving throttle the enging would not rev and spit ...
left it to go and get a tow bar and thought i would try and drive it back which off boost/lite throttle it seemed ok unlike earlier..
soon as i boost it, it trys to cut out again, can someone please look at my readings and tell me if they are good or not?
Sunday,27,May,2007,23:02:21
6K0 906 032 ,,1.8L R4/20VT SEA 0002,
,Group A:,'003,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Mass Flow,Load,Ign. Timing,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, g/s,%, °BTDC,STAMP,,,,,STAMP,,,,
,0.01,920,4.72,3.5,8.3,,,,,,,,,,
,0.57,920,4.92,3.5,9.0,,,,,,,,,,
,1.25,960,5.06,3.5,6.8,,,,,,,,,,
Sunday,27,May,2007,23:03:17
,0.01,1040,5.92,5.5,25.5,,,,,,,,,,
,0.51,1080,8.19,7.8,18.8,,,,,,,,,,
,1.10,1200,12.58,13.3,21.8,,,,,,,,,,
,1.61,1400,18.58,100.0,14.3,,,,,,,,,,
,2.21,1720,25.56,100.0,13.5,,,,,,,,,,
,2.80,2000,34.75,100.0,11.3,,,,,,,,,,
,3.40,2360,46.69,100.0,8.3,,,,,,,,,,
,4.11,2760,57.22,100.0,12.0,,,,,,,,,,
,4.79,3280,67.22,100.0,13.5,,,,,,,,,,
,5.31,3760,76.56,100.0,15.0,,,,,,,,,,
,5.90,4080,73.86,100.0,17.3,,,,,,,,,,
,6.50,4520,84.83,100.0,18.0,,,,,,,,,,
,7.00,4720,68.11,100.0,25.5,,,,,,,,,,
,7.52,5080,118.33,100.0,20.3,,,,,,,,,,
,8.12,5440,80.31,100.0,25.5,,,,,,,,,,
,8.71,5800,10.81,44.3,19.5,,,,,,,,,,
,9.40,5440,7.97,7.8,15.8,,,,,,,,,,
,10.09,4840,10.64,8.2,13.5,,,,,,,,,,
,10.60,4280,9.44,7.5,12.8,,,,,,,,,,
,11.24,3720,8.31,6.3,12.8,,,,,,,,,,
,11.80,3240,7.06,5.5,12.8,,,,,,,,,,
,12.30,2880,6.36,4.7,12.8,,,,,,,,,,
,12.90,2560,5.56,3.9,12.8,,,,,,,,,,
,13.50,2320,5.08,3.1,9.8,,,,,,,,,,
,14.11,2080,4.28,2.7,7.5,,,,,,,,,,
,14.84,1920,4.72,2.7,5.3,,,,,,,,,,
,15.47,1760,3.72,2.4,4.5,,,,,,,,,,
,16.00,1640,3.75,2.4,1.5,,,,,,,,,,
,16.61,1600,4.47,2.7,21.0,,,,,,,,,,
,17.22,1280,4.28,3.9,25.5,,,,,,,,,,
,17.80,1200,4.58,2.7,8.3,,,,,,,,,,
,18.39,960,3.83,2.4,11.3,,,,,,,,,,
,18.99,920,3.83,2.4,11.3,,,,,,,,,,
,19.61,920,4.14,2.7,15.8,,,,,,,,,,
,20.31,920,4.42,2.7,9.0,,,,,,,,,,
,20.92,920,4.42,2.7,9.8,,,,,,,,,,
,21.52,920,5.00,3.5,0.8,,,,,,,,,,
,22.09,920,4.14,2.7,4.5,,,,,,,,,,
,22.68,960,5.61,3.9,0.8,,,,,,,,,,
,23.19,960,5.00,3.5,0.0,,,,,,,,,,
,23.78,920,5.03,3.5,1.5,,,,,,,,,,
,24.39,960,4.08,2.7,3.0,,,,,,,,,,
,24.99,960,4.44,2.7,2.3,,,,,,,,,,
,25.72,920,4.47,3.1,8.3,,,,,,,,,,
,26.31,960,3.97,2.7,6.0,,,,,,,,,,
,26.90,2360,33.89,28.2,32.3,,,,,,,,,,
,27.49,2880,45.14,71.4,24.8,,,,,,,,,,
,28.09,3160,43.75,32.5,24.0,,,,,,,,,,
,28.70,3640,40.67,24.3,28.5,,,,,,,,,,
,29.29,3440,47.67,32.5,26.3,,,,,,,,,,
,29.89,4240,67.69,100.0,26.3,,,,,,,,,,
,30.51,5240,127.11,100.0,12.8,,,,,,,,,,
,31.21,6160,94.28,100.0,23.3,,,,,,,,,,
,31.84,5400,8.92,6.3,15.0,,,,,,,,,,
,32.42,3640,41.58,91.0,31.5,,,,,,,,,,
,32.99,4000,67.39,100.0,26.3,,,,,,,,,,
,33.60,4440,203.50,100.0,15.8,,,,,,,,,,
,34.21,4480,100.00,99.6,14.3,,,,,,,,,,
,34.79,4880,73.58,100.0,17.3,,,,,,,,,,
,35.39,5400,83.44,100.0,22.5,,,,,,,,,,
,36.03,5040,56.86,18.4,6.0,,,,,,,,,,
,36.67,4160,5.78,5.1,13.5,,,,,,,,,,
,37.23,3200,6.06,5.1,12.8,,,,,,,,,,
,37.79,2280,4.67,3.1,9.8,,,,,,,,,,
,38.38,1440,4.53,3.1,13.5,,,,,,,,,,
,38.99,1160,4.53,3.1,5.3,,,,,,,,,,
,39.59,960,4.97,2.7,4.5,,,,,,,,,,
,40.18,920,3.64,2.4,12.8,,,,,,,,,,
,40.79,920,3.83,2.4,11.3,,,,,,,,,,
also i got this fault code which i guess could be a broken wire... is there a common place for a wire to break or a reason for this code to come up??
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
thanks guys, lee.
P1602 - 35-00 - -
thanks guys, lee.
