Maf again????
Katy
Hi I have a 01 cupra about a year ago I got the emmisions light and intemitent loss of power, eventually replaced the maf sensor instantly everything was back to normal. Recently the idle is eratic /low and now the light is back on and starting the power loss again. could it be the maf again?? so soon.:cartman:
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Its not unlikely as they are really delicate and not the most relyable!!
Apparently if you unplug it and drive (Not to far), it will give you an idea of whether the MAF is making things worse. If there is no change to the way it runs, you know its not that.
Try asking on the VAG-COM area if someone could plug in and read the fault code. I would help but its a bit far from me!!
