ive been told uprating the cams in an abf engine doesn't have any affect on performance is this true.
dont do it - the std ECU cannot cope
Thanx will keep that in mind before I do ought, remaps dont seem worth it when running N/A.
I see, I have to decide which duration to go for I would still like it to be drivable round town etc.
welll..ive got cams in mine at the mo, kent ones. The only downfall ive found sooo far with them is the fuel consumption which cos im still running the standard ecu is (problem solved when you get mapped) erm...car runns quite rich on idle too (solved when mapped) lol but you definatly notice the perfomance increase with cams. il make a video and post it on youtube of what cams do on idle, hope this helps.
not solved by map tho most likely.. as its not mappable on lambda control, which it gets upset by seeing wider duration/overlap cam..
change the ECU to one that does not use lambda or MAP for fuel control
