Ok please bear with me because im pretty noobish when it comes to mechanics/cars.
I recently purchased an 8V mk2 ibiza 2.0 jobby and im over the moon with it.
However last night when driving to the gym from home i experienced my first issue with the car. (and im sure more are to follow)
After a fresh start (been sitting all day as i use a work van to get to and from work) the car started fine but when pulling off in first (fairly shortly after starting) the car seemed to kangaroo (and no it was not a sloppy clutch lift ) This only happened in first gear from the fresh start.
After gyming it happened again on first start. But again only in first gear and for the first pull off. Any other first gear pull off after that was fine?
Any ideas on that one?
Not sure if this is relevant but im getting the cam belt changed soon (as its due) and might get the chap to check over the usual throttle body clean and plugs and leads etc.
Cheers in advance.
Cheers in advance.
