Lost power after fitting BMC CDA!!!
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Horsham, West Sussex
Just finished fitting my BMC CDA in my LCR 210 and took her for a spin but i have noticed that there is a lack of 'pull' and too much wooshing sound coming from under the bonnet??? :shrug:
I have an uprated forge 007 DV so not sure its that unless the spring is too weak and is letting air escape when under load???:confused:
Help needed please somebody! :D
Andi
Back in Black
Mar 5, 2006
493
Inverness
I recently fitted a BMC CDA to my 210 and i felt a very slight gain.
Something does sound wrong there mate.
leon7284
Chelsea Chelsea
Jun 13, 2006
365
:( how did it sound after you had fitted it? Did you get alot of air sound as you accellerated or is it just a smooth groan sound like it wants 'to go some'? :confused:
:lol: Im so worried now i thought i would have a phat grin on my face!:-o
Andi
Back in Black
Mar 5, 2006
493
Inverness
The sounds i get are very wooshy and you can hear alot of turbo spool. so not to worry about that.
leon7284
Chelsea Chelsea
Jun 13, 2006
365
oh ok then, it just seems that when accellerating smoothly its really wooshy and no throttle response but then under load it doesnt pull untill in the high revs and then thats when the wooshing goes quiet.
Ive seen posts about reversing the DV could this fix it maybe? Do you think its not a wise idea to test it out?
Mitchy
TTRS
Oct 12, 2004
2,310
Thats normal, you can hear the filter suck in a lot of air and you'll hear a slight 'woosh' on lift off!
Have you connected it to the original air duct?
Perhaps your MAF is knackered?
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Yes i have replaced that plastic bit which connected the standard air box to the vent next to the nearside headlamp. Is this ok or best to do something fancy with the fog lamps like others???
Is there anyway that i can test my MAF sensor without vag com?
honeyman
Pirates
Oct 20, 2004
614
Northampton
when under load the DV is open not sealing anything. I found changing back to the green spring helped mine as I found the yellow (stronger) spring dumping as soon as I lifted off only slightly.
leon7284
Chelsea Chelsea
Jun 13, 2006
365
I havent got a clue what colour spring i have! Im going to put my standard DV back in and see if there is any difference if there is then ill get that pack of three different colour springs for my uprated DV.
Cheers for your help mate.
NeilC
Has left the fold...
Mar 23, 2004
336
somewhere else
Check the black rubber ring is between the maf and the bmc to give a good seal. I think mine came off as was stuck on the box (its been a long time tho).
Could disconnect maf and go for a short run to see if it makes a diff (it should be much slower without). Think there's a sensor connects to it you can unplug.
NeilC
Mar 23, 2004
336
somewhere else
You only need to worry about springs if your cars been remapped and even then only sometimes. Also, why would it suddenly go weak 2 seconds after installing an air filter? They dont give that much power you know!
Or even stick the original airbox back on and see what happens?
leon7284
Chelsea Chelsea
Jun 13, 2006
365
That black spongy bit is ok but cant be bothered to try standard airbox till weekend its getting darker in the evenings now by the time i get in from work!
Cheers for the help NeilC top bloke
Ju.
461
Bradford
I tried the BMC on mine, but took it back off, It felt slugish compared to my Dynatwist . Logs with vagcom showed it flowed less aswell.
Shame really cos it looked great under bonnet!!
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
I had
Standard Airbox + green filter
BMC
And one other
I had the same performance with all 3 but the BMC sounded way better the std airbox.
Maybe you knocked the MAF and it's under reading you need a full power 3rd and 4th gear run and see the max G/s your pulling....should be circa 195
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Erm sounds like Vag com stuff i havent got access to that- wish i did! :p
You say 'knocked the MAF' i unplugged it and took it out so it was easier to get the BMC in should i not have done this??? :shrug:
Is there by any chance that by disconnecting the battery for couple of minutes then reconnecting it will 'restet' the MAF and all would be well? :confused:
Ju.
461
Bradford
Logs taken from my car APR Stage 1
Standard airbox
/min g/s
1480 26.42
1720 32.39
1920 41.33
2240 63.58
2640 85.94
3040 100.25
3440 118.39
3880 135.08
4320 141.53
4640 145.78
5000 159.47
5360 175.83
5680 182.75
5920 183.03
6160 125.19
4720 14.97
BMC CDA
/min g/s
1320 21.36
1480 24.03
1640 30.33
1840 33.5
2040 41.39
2320 54.92
2720 85.28
3120 96.69
3560 131.44
3960 143.83
4360 153.58
4800 167.47
5200 175.58
5520 181.25
5760 175.69
6040 172.53
6240 167.72
6480 163.56
6640 164.64
6800 163.81
7000 165.81
Dynatwist
/min g/s
1840 32.06
2040 42.31
2400 63.06
2800 97.42
3280 121.67
3800 143.11
4360 157.72
4840 164.78
5240 178.83
5600 182.14
5920 186.06
6200 189.56
6480 185.75
6680 183.08
6920 183.47
7040 161.08
NeilC
Mar 23, 2004
336
somewhere else
Standard airbox
/min g/s
1480 26.42
1720 32.39
1920 41.33
2240 63.58
2640 85.94
3040 100.25
3440 118.39
3880 135.08
4320 141.53
4640 145.78
5000 159.47
5360 175.83
5680 182.75
5920 183.03
6160 125.19
4720 14.97
BMC CDA
/min g/s
1320 21.36
1480 24.03
1640 30.33
1840 33.5
2040 41.39
2320 54.92
2720 85.28
3120 96.69
3560 131.44
3960 143.83
4360 153.58
4800 167.47
5200 175.58
5520 181.25
5760 175.69
6040 172.53
6240 167.72
6480 163.56
6640 164.64
6800 163.81
7000 165.81
Dynatwist
/min g/s
1840 32.06
2040 42.31
2400 63.06
2800 97.42
3280 121.67
3800 143.11
4360 157.72
4840 164.78
5240 178.83
5600 182.14
5920 186.06
6200 189.56
6480 185.75
6680 183.08
6920 183.47
7040 161.08
Is it just me or are those readings a bit low? :confused: I normally see 200-220 depending on weather. An apr thing maybe?
NeilC
Mar 23, 2004
336
somewhere else
What does that tell you? Sorry but i need to learn all this stuff i want to get the software on my laptop i already have the connection lead
You can do a rough estimate of bhp by multiplying the max g/s throughput of the maf by 1.31. In theory anyway as it can go above what the turbo is rated for, but is good enough estimate for most.
You can download the older versions for free from the vagcom site. I dont think they allow logging the block you need but i suppose you could get someone to sit and read you the instantaneuos readout.
If you look in the revo section on here there is a link to a guide called sps3 advanced users guide or similar, this will give you all you need for vagcom logging.
