Every 50 miles is really frequent!! Mine was never that frequent. I’d recommend you carry out a compression test on the block. Check your oil for any water. Do you get a loss in boost? Judging from how frequent your bottle empties I’m guessing it’s not the same problemYes every 50 miles expansion bottle empty . I bypass egr and so heater matrix still the same new water pump
problem sorted had to go back to seat company and get cooling system flushed and then vacuumed all the air out of systemAfter all these months and no nearer to a solution. I've just kinda learned to live with it. It's not doing it as ofter as usual now, usually around every three months (5000 miles) so just top up the expansion tank when it does. Although I can kind of guess when it does it now. Ive noticed that if the car loses boost (doesn't feel as torquey as it should) the coolant overflow occurs then and after a top up its back to normal. R U having similar issues?
Did you get this sorted mate?My Leon FR is having the exactly the same problem for about 3 months now, and it is happening more often and now on weekly basis. The coolant blowing out of the expansion tank and then drop to very low level, temperature on dashboard always fine and I replaced the cap as well. Got is checked in 3 different garages and they could not find any problems. So annoying...
any potential for air traps/locks? and what is the level like when its up to temperature and had a good run?
I would take the cap off (when cold), start the car up leaving cap off/loose, let it run up to operating temperature, leave it running for a period. then leave it to fully cool down (a few hours) before reviewing the level and replacing the cap. if the level dropped it would indicate you got some air out of the system.
Hi my problem was head gasketI have the same problem.
I have had a new water pump, expansion tank and cap, system flushed out. Even took the heater matrix out and flushed it out and it was very clean with good flow of water. It's been pressure tested which was time too.
Each time I drive for more than about an hour the coolant comes out of the expansion tank overflow. Temperature on the car always says it's 90 degrees and no higher when it gets warmer up.
I did notice as well that when I put the heater on hot it will only blow warm air out of the passenger side and cool air out of the driver side vents!
It's frustrating as hell to find out what's wrong and if the heater and coolant loss are connected.
Any advice of what to check next or what the problem could be would be very much appreciated.
Paul
I don't have any of the tell tale signs such as milky oil, coolant leaking from the exhaust manifold, bubbles in my coolant, white smoke etc!!Oh dear, I was hoping it would be something simpler
Nor do I. What I have found is that if I only top it up to the minimum line, then it doesn't leak half as much. The coolant level rises to the max line though once the engine is warm. Probably needs topping up once a week after approx 300 miles or so. Got it booked in for a service on friday and also to have a look at the issue. Hopefully we find something :/I don't have any of the tell tale signs such as milky oil, coolant leaking from the exhaust manifold, bubbles in my coolant, white smoke etc!!
Last week my coolant didn't rise and overflow so that was a welcome change. Still haven't got any hot air through my driver side vents though.Nor do I. What I have found is that if I only top it up to the minimum line, then it doesn't leak half as much. The coolant level rises to the max line though once the engine is warm. Probably needs topping up once a week after approx 300 miles or so. Got it booked in for a service on friday and also to have a look at the issue. Hopefully we find something :/
Hi..
Is there some news / Update on the problem? I have one that does the same as yours, we have allso change the waterpump and have it messured for leaks,
Good day all
