Thought would put these in here to see if anyone can see any problems?
All runs done in 3rd gear from 2500rpm to red line ... wanting to retain my licence I wasnt happy doing them in 4th gear.
Groups 003 and 020
Groups 115 and 031
Groups 118 and 032
Groups 002 and 120
Comments?
Can anyone tell me if any issues with timing or vacuum leaks from these logs?
Groups 003 and 020
Code:
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME
Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.59 2760 73.78 100 13.5 1.01 0 0 3 3
1.5 3320 110.06 100 5.3 1.9 0 0 3 3
2.3 3760 115.03 100 6.8 2.7 0 0 3 3
3.12 4160 134.06 100 12 3.52 0 0 2.3 2.3
3.92 4560 149.89 100 10.5 4.33 3 0 2.3 2.3
4.83 5000 162.75 100 9.8 5.23 3 3 1.5 2.3
5.72 5400 168.33 100 12 6.14 3 3 1.5 1.5
6.64 5760 172.67 100 12 7.04 2.3 2.3 1.5 1.5
7.45 6040 176.69 100 9.8 7.95 2.3 2.3 0.8 1.5
8.35 6280 178.14 100 12 8.75 1.5 1.5 0.8 0.8
9.15 6520 179.83 100 11.3 9.55 0 0 0 0
10.06 4920 10.56 5.9 4.5 10.44 0 0 0 0
10.86 3240 5.44 4.3 1.5 11.36 0 0 0 0
11.76 3240 6.58 4.7 1.5 12.16 0 0 0 0
12.57 3120 6.89 5.1 1.5 13.07 0 0 0 0
13.47 3040 7.06 5.1 1.5 13.87 0 0 0 0
14.27 3000 10.58 7.1 29.3 14.68 0 0 0 0
Groups 115 and 031
Code:
Group A: '115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor Bin. Bits
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
STAMP /min % mbar mbar STAMP
0.4 2000 88 1510 1250 0.01 0.984 1
1.21 2320 121.8 1980 1550 0.8 0.961 1
2.01 2680 152.6 2080 1950 1.61 0.992 1
2.81 3080 164.7 2020 2040 2.41 0.953 0.953
3.61 3440 167.7 2010 2020 3.21 0.852 0.852
4.43 3840 161.7 2050 1990 4.03 0.789 0.797
5.25 4240 169.9 2060 2070 4.83 0.75 0.789
6.14 4680 168.4 2060 2040 5.73 0.75 0.782
6.94 5040 169.2 2060 2040 6.54 0.75 0.766
7.84 5440 163.2 2100 1970 7.44 0.75 0.688
8.76 5800 158.6 2030 1850 8.25 0.75 0.649
9.66 6120 149.6 1830 1810 9.16 0.75 0.649
10.48 6360 145.9 1640 1800 10.06 0.75 0.649
11.28 5640 10.5 1000 1140 10.88 0.899 0.891
12.08 4000 12.8 1000 1070 11.68 0.852 0.977
12.97 2680 12.8 1000 1040 12.57 1.991 1.047
13.98 2320 13.5 1000 1030 13.48 1.991 1.047
14.78 2120 12 1000 1030 14.38 1.991 1.047
15.6 1960 12.8 1000 1030 15.18 1.991 1.047
16.4 1920 13.5 1000 1020 15.98 1.991 1.047
17.29 1800 13.5 1000 1020 16.89 1.991 1.047
Groups 118 and 032
Code:
Group A: '118 Group B: '032
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME -10.1 -10.1
STAMP /min °C % mbar STAMP % %
0.53 2280 34 95.3 1440 0.93 0.8 -8.6
1.33 2600 34 95.3 1830 1.73 0.8 -8.6
2.15 3000 34 77.6 2110 2.65 0.8 -8.6
3.05 3440 35 77.3 2010 3.56 0.8 -8.6
4.05 3880 36 80.8 1990 4.45 0.8 -8.6
4.85 4240 37 83.1 2110 5.27 0.8 -8.6
5.78 4600 39 83.5 2060 6.17 0.8 -8.6
6.58 4960 41 89.8 2030 6.97 0.8 -7.8
7.38 5280 44 95.3 1970 7.88 0.8 -7.8
8.29 5600 47 95.3 1920 8.69 0.8 -7.8
9.19 5880 50 95.3 1880 9.59 0.8 -7.8
9.99 6120 52 75.3 1840 10.39 0.8 -7.8
10.81 6320 54 54.9 1470 11.21 0.8 -8.6
11.6 6400 53 0 1250 12 0.8 -8.6
12.4 5600 50 0 1060 12.8 0.8 -8.6
13.2 3600 48 0 1050 13.72 0.8 -8.6
14.21 2640 46 0 1030 14.61 0.8 -8.6
15.01 2480 45 0 1030 15.41 0.8 -8.6
15.83 2360 45 0 1030 16.23 0.8 -8.6
16.72 2240 45 0 1030 17.12 0.8 -8.6
17.54 2120 45 0 1020 18.02 0.8 -8.6
18.44 1960 44 0 1020 18.84 0.8 -8.6
Groups 002 and 120
Code:
Group A: '002 Group B: '120 Group C:
Idle speed Engine load Inj. period Air mass in Engine Speed Spec Load Curr Load ASR Status
TIME 700-820 rpm 15-25% 2.0 - 4.0 ms 2.0-4.5 g/s TIME 700-6800 RPM 0-399 Nm 0-260 Nm active yes/no TIME
STAMP /min % ms g/s STAMP /min Nm Nm STAMP
0.01 1880 70.7 8.16 30.64 0.5 2040 399.8 178.4 ASR OFF
0.9 2160 106 11.22 47.08 1.29 2280 399.8 221.5 ASR OFF
1.7 2480 130.8 13.94 65.89 2.11 2640 399.8 266.6 ASR OFF
2.51 2840 158.6 17 89.75 3.01 3080 399.8 309.7 ASR OFF
3.41 3280 163.9 18.7 103.83 3.81 3480 399.8 301.8 ASR OFF
4.22 3640 163.2 19.72 114.36 4.72 3880 399.8 290.1 ASR OFF
5.12 4080 166.2 23.46 129.53 5.52 4240 399.8 288.1 ASR OFF
5.92 4400 166.2 23.46 139.36 6.33 4600 399.8 284.2 ASR OFF
6.73 4760 166.9 24.14 151.75 7.15 4920 399.8 270.5 ASR OFF
7.63 5120 164.7 25.84 159.67 8.03 5240 399.8 258.7 ASR OFF
8.45 5400 160.9 26.86 166 8.94 5600 399.8 243 ASR OFF
9.34 5720 158.6 27.2 172.75 9.85 5880 399.8 227.4 ASR OFF
10.37 6000 115.8 18.7 135.14 10.85 6080 399.8 203.8 ASR OFF
11.26 6120 119.5 19.04 138.86 11.66 5920 399.8 35.3 ASR OFF
12.06 5360 11.3 1.7 15.94 12.48 4760 399.8 0 ASR OFF
12.97 4080 12 1.36 9.47 13.47 2840 399.8 0 ASR OFF
13.87 2760 12.8 0 5.11 14.27 2680 399.8 0 ASR OFF
14.67 2600 12.8 0 6.5 15.09 2520 399.8 0 ASR OFF
15.49 2480 12.8 0 6.53 15.89 2440 399.8 0 ASR OFF
16.29 2400 13.5 0 6.33 16.69 2360 399.8 0 ASR OFF
17.2 2280 13.5 0 6.14 17.6 2240 399.8 0 ASR OFF
18 2200 13.5 0 5.86 18.4 2160 399.8 0 ASR OFF
18.8 2120 12.8 0 5.5 19.31 2080 399.8 0 ASR OFF
19.71 2080 13.5 0 5.42 20.11 2040 399.8 0 ASR OFF
20.51 2040 13.5 0 5.33 20.91 2000 399.8 0 ASR OFF
21.31 1880 13.5 0 5.25 21.71 2040 399.8 70.6 ASR OFF
22.12 2120 12.8 2.04 4.31 22.62 2000 399.8 0 ASR OFF
23.02 2040 12.8 0 4.56 23.42 2320 399.8 0 ASR OFF
23.84 2240 13.5 0 6.03 24.33 2240 399.8 43.1 ASR OFF
24.73 2640 12.8 2.04 1.72 25.13 3520 399.8 0 ASR OFF
25.53 3440 12 0 7.97 25.95 3400 399.8 0 ASR OFF
26.46 3400 23.3 3.4 16.56 26.94 3320 399.8 5.9 ASR OFF
27.36 3160 12.8 1.7 7.11 27.75 2800 399.8 0 ASR OFF
28.25 1920 39.8 4.76 14.75 28.65 1720 399.8 54.9 ASR OFF
29.05 1720 35.3 4.08 11.97 29.47 1720 399.8 51 ASR OFF
29.87 1760 32.3 3.74 11.06 30.27 1760 399.8 43.1 ASR OFF
30.67 1720 16.5 2.04 2 31.07 1720 399.8 3.9 ASR OFF
31.47 1720 12.8 1.7 4.08 31.87 1720 399.8 0 ASR OFF
32.28 1720 12 1.7 4.11 32.68 1680 399.8 0 ASR OFF
Comments?
