Logging Results - look in - high CF values?
dave_6
193
Essex
Hi all
Seat Ibiza Cupra 2001 X reg 1.8 20v T mk3
Have now finished removing my SAI and have a resistor in the N112 plug, no fault codes at all now
Thought I'd do some logs to see how things are.
Outside temp was 18 degrees, runs done in 3rd and 4th gear, mostly 3rd!
Car was bought with aquamist running but I've since disconnected it so I have a feeling the timing may need to come back a bit! getting some high CF values by the looks of things
Mods are in my sig! running a Laguna intercooler
Maf is 6 months old!
Car seems to be driving really well, still very happy with it and seems to be running well but maybe the figures show differently?
What do you think to the logs? The CF values are a bit high going by searches i've done, and seen many mentions of using Lemmiwinks to change timing slightly. although most go forwards I'd need to go back if I did look into it...
anyway the logs
Dave
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
MAF reading as low and boost is all over the place.
If it was running WMI and you have turned it off the timing will need to be turned down, like you said.
dave_6
193
Essex
If I was to use lemmiwinks, think I read you need to remove fuse 27 to get it to connect.
Then it may or may not work with mine anyway as its a custom jabbasport map
Have vagcom, but using a cable from alphabid
Damoegan
Oct 15, 2007
8,993
Newcastle
Lemmiwinks will do it fine but I dont know how to get it to work on anything other than the mk4 ibiza. I have a cable from ebay and it works with lemmiwinks fine.
It dont matter what map you are running mate.
dave_6
193
Essex
got it working on the mk3! turned the timing down 0.75 degrees so far so I'll log now and see if theres much difference
