594pidge
how do u kno if your cars gone into limp mode?? got a ecu warning light on, but the car doesnt feel any differant to drive?
remember spelling ;) if your car goes into limp mode, you will know about, it will feel so sluggish
what warning light is it?
I'm guessing that could be a number of things mate? just something daft? When your car goes into limp mode u know that when u go to floor it then it will not boost! (Yours doing that?)
nope dosn't feel sluggish, can still here the turbo spooling up, and my DV is still 'wooshing'....
the warning light coming on wont always mean its in limp mode. but it has logged a fault which needs reading with expensive dealer diagnostics, or a friendly local scn member who has vagcom software:) have a look in the vagcom requests section of the forum
as acid said... try disconnecting the battery first and see if it goes
My LC did the same thing when the Lambda sensor connections got wet. Whatever your problem it's going to be pretty minor, but it will likely require VAG-COM to diagnose.
I was waiting for the missus as always and saw a AA free check thing so got them to do a quick scan...
I'm sure there is a webby that will show you any AA free check things in your area.
Allan
Yeh its ur engine management light which can be a number of things (normally minor, sensors etc). I had a simular issue l8ly and it turned out to be one of the lambder sensors being knackerd. I never thaught my car was running to sluggish either until I changed it and the difference was definately noticable.
