Also what size spline & location of the bolts for back seats?
Front I believe is 4x 10mm spline bolts
Any correct method required though for disconnecting the Airbag?
Why am I all of a sudden thinking there aren't any in the seats lol?
Id imagine it just unplugs and all airbags are automatically disabled, however I know Al has had his out so perhaps drop him a PM
Am I correct in thinking the rear bench just pulls out?
Cheers Mike, David is a friend of mine,
I done mine ages ago Mike, think there is two plastic caps, you will see them at the back of the seats and the splines are below them, can't remember the size, think I used a similar sized allen key to get them out.......lol, when they are out, the back part of the seats come out in two parts, just pull the seats out on either side one by one, then the bottom of the seat is connected by two clips if you pull them hard they release,
Not sure not done that![]()
Ok update fitting the battery is a peice of p!ss.
It says in the destructions that you can lay the battery down so i just put the heavy duty velcro on one side and on the base.
Obviously as its now layed down its more stable infact when i first stuck the battery down it was in the wrong place and fook me just about got it unstuck. Theres no way that battery is going anywhere unless you have a crow bar
Taking the seats out is tomorrows job, if a fail with the front seat ill just get Steve@statllers to do it next Saturday.
No worries Mike..., it might not get to him tho...
