"light left on" buzzer
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
hmm that is the first time i have heard of it on here, mine has done it for a few seconds but it has worked since i said what the **** u playin at lol (its been good to me ever since) maybe u might have to wait till later on when some1 knows what has gone on... (sorry just got in from the town)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
well im guessing that u have your lights turned on? and opened the door? that should make the buzzer go off...
with the key out the ignition ?
try it with the passenger door
does the interior light work ok ?
and make sure the indicators are not on too
BJM
739
Houston, Renfrewshire
When you take the key out the ignition with the doors closed, does the interior ligh illuminate?
Flapper - when i leave the parking light on, via indicator stalk, my lights on buzzer still sounds - going by your reply it sounds like yours dont?
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
ive heard of this a few times on here! try a search but im quite sure its a new door catch job! as the open close switch/sensor has given up
Ant FR
2,861
Kent
I would suggest you get it looked at as it will also mean your alarm won't work either by opening the door. not ideal. Easiest way to check is either use Vag com you can live check the door triggers. or sit in car take key out of ignitionso light comes on, then wait 20-30 secs for this to go out, then open drivers door and it should turn light on again, if not its busted, and as others say it is in the catch. Not exepnsive as its a common problem on all Vag car as most use the same catch. Usually drivers door that goes first too. my mates old golf did this, his was worse though as would keep beeping saying drivers door still open whilst driving along. Pretty sure it was about 55 quid to source parts for his golf.
