Leon TDI FR Strut Brace Question
anorak
ok - had a search through the forums and cant seem to find a definitive answer to this one. When you guys/girls fitted a lower strut brace to a tdi leon fr/cupra did you have to remove the engine under tray or did you just bolt it on and squash the tray up a little?
anorak
ok - incase its of use to others, I have been reliably informed that yes you do need to remove the undertray thing
oops...
now where did i put those axel stands.....;)
Craig Senior
I've been Tango'd
May 24, 2004
1,099
Yorkshire
Missed this.
Yes you need to undo the back of the under tray, pull it down, fit the brace then refit the tray.
Should take about 10 mins (not including jacking)
