I'm gonna get booked in at shark this week for dpf removal and remap with egr delete. Still really can't decided between stage 1 and 2 and can't afford the STS at the same time.
Is stage 2 too smoky for daily use or is it ok? Also will it pass mot on stage 2. Iv read through the entire post and ppl say about passing the mot but without knowing the level of map there running it doesn't really help haha
Benzy be prepared to be back in the exhaust shop for a silencer fiting after the dpf is removed that thing stops so much noise its umbalivable
and once its remove and you have a straight thru system its one of the loadest tdi engines i have herd
be warned
make sure you tell shark to monitor egt's
i see lots of ther cars running 950c+ egt not so clever when the customer is not informed
Haha I'm supposed to be driving down to Devon in it in a week might have to act fast if its too loud then
Sounds nice Andrew! Did u end up fitting a silencer or left it as it was?
I'm not sure what you guys class as stage 2, but I know when I had mine done a month or two ago shark classed stage 2 as the sort of power you get with uprated turbos/injectors/SMF etc so probably looking above 220bhp and that's probably the reason they're wary about going to 'stage 2'. Mines at 212 and the smokes silly enough so any more is rediculous.
i would just prefer to call it a custom remap made to work with the mods the customer has
Ye I agree. I said I was looking for something between 1 and 2. Asked to start at stage 2 and bring it down slowly until the smoke levels r acceptable. Ill b happy with 210 tbh
