Leon flip Key guide
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
ok took my transponder out of my non-flip remote key and put it into the new flip remote key.
locked the car door,
unlocked the car door,
put the non-remote key in and turned the ignition on
used the non-flip remote key with no transponder in to lock the door with the non-remote key still in the ignition,
then left that key in the lock,
press unlock on the new flip remote key with the non flip remote keys transponder in
waited 6 seconds and pressed in again
NOTHING! :(
tillred
Heres my 2 penith worth
1.If you started with a non-flip remote you can not get a flip remote to work the remote locking?
2.If you started with a flip remote you can buy another flip key,put the transponder into it from the spare & u can also sync the key to the remote locking(something do do with frequencies?)
curryholic
169
In zomerzet
If you started with a non flip remote you can do a flip remote, follow the instructions and have a play around and it will eventually work, you may need a stealer to programme the new transponder but if reusing and old one you should be ok!
It worked for me and I had a non flip remote.
stevie steve
322
Clevedon
Worked for me - thats why I did the guide
tillred
Thats great :) Can you lads tell me what flip key I need.... part number & frequency.I had a 2 button non flip & my car is a mk1 seat Leon 20vt.Thanks
stevie steve
322
Clevedon
Mine was brought off ebay. Was from a golf mk 4 I believe, not sure really.
Like I mentioned the frequency didn't matter for me. Just swapped the bits over, did the recode and job done.
tillred
THanks for all your help much appreciated.Just ordered a Seat 2 button flip with uncut blade.Will put a fresh transponder in & hopefully it'll all work :cheers:
stevie steve
322
Clevedon
No you need to keep the transponder from your old key, recode it how I said, by putting it in the new key.
A new transponder will have to be coded = £££
tillred
Just thought I should clear this up.I had 2 keys....one 2 button remote & one non remote spare.
About a year ago I tried to take the transponder out of the spare & as usual ended up breaking it.So now left with only 1 working key which I managed to lose:cry:.Hence the new transponder for the spare:D.I'm getting the transponder coded today @ 50 notes all in so not to bad :rolleyes: When the flip key I've ordered arrives I'll put the transponder from my now recoded spare into the flip,get the blade cut & then follow your guide as how co code it so it works the remote locking.Once again thanks for the info from all :clap::clap:
curryholic
169
In zomerzet
The one in my pocket is a 3 button one that I got off ebay (got 2 because I mullered the first one!!!). It's got a coding of HLO1K0 959 753 and says 434 MHz on it.
I also got my transponder coded into the immobiliser for just under £50 (less than an hour for a technician).
Hope this helps.
redtill
black magic
Jan 30, 2002
172
suttoncoldfield
Hope this helps.
I phoned 3 dealers..sorry stealers & got 3 quotes ...47+,70+ & 90+.Found a company that come to your car & do it 50 all in
Also I'm the same user 'tillred' couldn't remember the log in for this username so reregistered.Obviously now remember the log in for my original username:redface:
volvic
It's just water
Jun 28, 2008
791
House of Batiatus
I had mine done at a dealer at £47ish inc vat. Make sure that company won't charge you if they cannot read the key. Mine had to be done at a dealer as no one could read it (I had the key code too)
Mark300zx
1,455
8
Surrey/SW London
I have a working key/fob and a spare key/no fob, would it be advisable to get a spare fob in case of emergencies, or is there a way of running the car with just the spare key?
Also I see there are plenty of 434Mhz fobs on ebay, but how much bearing does the part number on the fob working with my car?
