Leon Cupra exhuast
Deleted member 7729
What's the expected lifespan of a 2003 Cupra exhaust? I'm just past the 62k barrier at the moment
Deleted member 7729
No just trying to budget things as in the past I've had new exhaust around this milage etc.
Can't afford it atm anyway as I start my new job on the 19th June and the missus just got made redundant today.
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
From experience, it depends on what sort of journey you do. If the car doesn't get time to warm up and blow the condensation through, it sits in the box and joints and they will rust :cry:
If you do loads of miles with good opportunities to give it a blast then the exhause is left nice and dry after the journey and will last longer. ;)
Deleted member 7729
Yeah JKM had to re-weld the brackets at the last service..
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Motorway mileage is great for exhausts as the heat does them good. Short stop-start journeys cause condensation which can reduce the lifespan considerably. So using that as a guide should give you an idea of what to expect. A bit of everything driving should see you well into 100k + :)
