Leon Boost Gauges | Oil Pressure etc - Which Gauge is the best match???
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
mite look at getting silver rings for the original clocks to match my gauges now
what bits do i need and where to plumb the oil temp stuff ,
it came with a sender is this ok or do i need more/different stuff
is there any point getting the no buzz kit ??
cheers
andrew
StokieShinobi
Cupra R Potter
cheers
andrew
I think the oil temp probe goes in instead of the sump plug, but I'm sure it's going to require some kind of adapter.
I'm going to go upto daemon tweaks as its not too far from me and get everything I need from them
paul-murphys
efr 6758 here i come
StokieShinobi
Cupra R Potter
im gettin boost gauge an oil temp gauge from halfords cause they look good..... where did you guys get pillars from? are they east to get hose from engine to the gauge an what you guts think off these pillars?
http://cgi.ebay.co.uk/Seat-Leon-Tol...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
how long of a job an how did you measure the temp? does anyone have a link? cheers guys
Dont get one of them, these are what you want - all built in and match well with standard pillar
http://www.nomadracing.com/catalog/product_info.php?cPath=56&products_id=439
turbin
hey can you use the same position for the temp sender as the oil pressure, which is on top on oil filter?
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
Don't think so, as you need to separate senders...prob have to use both options below...1 for Temp, 1 for Pressure.
so how to you get the oil temp feed from. The oil filter am i right in sayin. Cheers guys
With the gauge comes a Oil Temp sender. There are a couple of places to put it...
1. Just above the Oil filter (below the throttle body) there is a blanking plug that can be removed, and sender inserted (ensure thread matches!!)
2. Get a sump plug that has a hole to accept the sender into it, something like this:
StokieShinobi
Cupra R Potter
This is what I needed to know
Thanks a bunch :)
Andrewcupra TDI
Apr 30, 2008
3,282
had my a pillar pod from nomad , a 2 gauge one, finish isnt what i expected , but there we go , will see what its like in with the gauges , my hids came this morning aswell, so lots of things to do , with not enough time / help to do it !!
dmmsta
Feb 10, 2007
787
Maidstone - Kent
HID's are easy to fit, worst part is drilling the headlamp back plate.
Gauges are a little more fiddly, but nothing horrendous, just a little time consuming!
dmmsta
Feb 10, 2007
787
Maidstone - Kent
sorry just read what you put. so all i need to do is buy a plug to screw in temp sender into...cheers
If you are going to put the Temp sender into the sump, then yes all you need is the new sump plug...check out Demon Tweeks, not sure on size, but i'm sure it's on here somewhere!
andy_h
Do any of you guys use sandwitch plates? u know the think that goes between the oil filter and the block?
dmmsta
Feb 10, 2007
787
Maidstone - Kent
anyone had the halfords gauges fitted ???
did you use existing probe that came with the gauge or did u order a different one,
if used what size sump plug u use
cheers
andrew
I believe the Halfrauds gauges are Autogauge units, which I have, and I used the sender that came in the packet...just make sure the thread is the same!
