I really can't see what the problem is with regards fitting if you take your time, I managed to fit mine without cutting outside the lines of the coinholder, so there is no visible gaps. My entire centre console is leather as well which meant I had to be extra careful where I was cutting. It doesn't rattle, and the three location points for the bracket were easy enough to access (never heard of any snapping and requiring welding!!)
Mine is a genuine Seat leather one and cost me £130 from the main dealers.
Makes such a difference to drive it now!
I have just received an armrest from a guy in london through ebay. I have not started fitting yet but the earlier posts mention only being able to use two of the 3 mounting points. Is this due to the holes not lining up or the need for a special double ended bolt from VW?
You can see the bolt in question in picture no.1 - it is the black one - it seems to screw into the floor and then you attach the bracket by screwing into the top of this one.
http://homepage.ntlworld.com/barry.clark3/installing_an_armrest_on_a_golf.htm
Any ideas where I can get this one piece and not the whole set? is there a VW part no for the bolt?:confused::help:
i think the bolt is whats needed! god knows where you get it from tho
Love your LCR mate.
was drooling over it at edition 38, Who did your leather re-trim?
I have repaired the armrest last week, greased ratchet and other moving parts... and turned the inside in a nice, insulated, liquor cabinet :) pictures soon
~Nautilus
Completed the fitting of the armrest bought on ebay
http://cgi.ebay.co.uk/VW-Golf-Mk4-B...oryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Worked well but I did not remove the centre console completely and therefore I made the job alot harder when fitting the bolts!!:doh::doh:
I cut the straight edges using a dremel cutting disk and just used the stanley knife for the 4 corners.
Using the adapter bolt from VW (Part No.1J0711354V £3.28 incl. VAT) I was able to attach all 3 bolts.
Had to get a large allen key to tighten the screw fixing the armrest to the mount but apart from that no extra cost.
Very pleased with the finished result - material fits in well with my standard cupra seats.:coolthumb
You can see the VW adapter bolt in the 3rd picture (grey left hand side)
thats what i have ordered too, it was a different part number to what was stated though
I quoted part number 1J0711354V when I ordered the part but when I checked my receipt from VW it shows WHT 001 759.:confused:
Same part but with two different reference numbers - at least they knew what it was and got the correct part anyway.
As far a a simpler way to fit it - buy a genuine part and get your dealer to fit it. I cannot see another option.
