Is the rear bumper open? I thought it was 'sealed' from the bottom using the clips shown in your pic
I think you might have just wasted a bumper
The bumper is "technically" sealed, and I contemplated for some time to start drilling holes, but when you look closer at the pre-facelift, it's quite poorly sealed. The moulds which run from the bumper shell to the chassis aren't great and air easily runs between the poorly moulded lines and the rear bumper acts as a parachute almost.
I want to release that air which is causing lift on the rear at the moment at high speeds.
Not recommended, but the crash bar is going, so air flowing through the poorly moulded bumper seals will flow out through the large holes, releasing it, rather than trapping it, causing less drag and less lift on the rear.
My proper plans are to cut the spare wheel well out, weld a flat plate, and bolt on a proper diffuser, but this is a cheap and quick fix to releasing that air flow for now
Next is a big ass spoiler on the rear as the LCR spoiler is being removed to get some more down force as the rear is.....twitchy.....
