I have taken off the casings by the indicator light and by doing dome twisting etc the indicator works now and again. This may sound like a dumb question but how they hell do I get the bulb out?? there is a connector into the bulb casing and a connector into a socket on the main beam headlight area.
Which of these should come out and how much force should be applied? It seems to me it must be the 2 wires that lead into the actual bulb casing which need to come off but without using brute force and risking breaking it or trying to take off the wrong part I thought I would ask some advice from you peeps.
The manual says to push the release mechanism to release the connector but I cannot find anything like this!!
As you can tell I am a novice at this sort of thing.
