LED Footwell Lights
BoBdOg!
Disturbed1
Mar 22, 2011
121
Manchester UK
Hi guys sorry it's taken a while I've been away on holiday. Here are the pics!
Also changed the interior lights to led to match colour wise.
The whole car lights up inside a nice white colour.
BoBdOg!
Disturbed1
Mar 22, 2011
121
Manchester UK
Put a wiring diagram together mate so i can see where to hook up.
Looks smart, well done!
Thanks! It's dead simple follow this mate.
My red + goes to red with black stripe (middle) and my black to the blue wire.
These are located behind the center interior lights. Just pull the case off and there you go.
Ive tried them and they defo on/off when door open/shut!
Thanks to Jay for this.
Benzy
1,214
Looks good man, top job
Sent from my HTC Wildfire using Tapatalk
BoBdOg!
Disturbed1
Mar 22, 2011
121
Manchester UK
Which the interior light case? The clear plastic or the grey plastic which hold the whole interior light in the roof?
Take off the clear lens then there's 4 clips holding the grey casing into the roof. Take the grey case off and behind there is the loom which you can just push your wires into without having to splice.
Top Dog
220
Wolverhampton
The wire routing should be easy, I'm routing mine from the light down the passenger pillar, behind the glove box and across the footwells. Same route as my microphone takes for my head unit.
Cheers buddy, have you done the the back footwells aswell if so, how did you route them? With the fronts did you pass both passenger and driver side led wire through passenger pilliar? Last question which led strips did you buy from ebay?
Sorry for all the questions but never done this sort of thing before so want to get it right.
BoBdOg!
Disturbed1
Mar 22, 2011
121
Manchester UK
No but they're next, i would possible route the wiring under the carpets if its easy enough to do. I linked the 2 strips together under the steering wheel then ran my wires from the light down the drivers side pillar as it was easier to access. All the wiring is just behind the fuse board.
The guy I bought the lights off doesn't exist anymore, but they only cost me £2.00 they're flexible LED strips, but I'm thinking of changing them to tubes as they are easier to mount.
Not a problem matey have fun!
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
Just having a think about this and have one question. The cables running up to the centre light, can you not just take a feed from there; i.e. at the bottom of the A pillar? To prevent going all across the headliner and messing with the light unit?
