Can you fit non-CupraR suspension to a LCR if you change the wishbones and front ARB ?
and what I'm really fishing for .... is there any advantage to be gained by fitting LCR coilovers in place of my Toledo/Cupra ones ?
Better clearance between 'shafts and ARB maybe ??![]()
Well your right the LCR suspension is set up on the front with ARB carrier on the bottom of the damper, so you will need some adaptation for the Cupra/Toledo.
The rear end of any LCR suspension kit is effectively MK4 Golf/Cupra/toledo so no issues there.
As for clearance the LCR is meant to have a different rack also coupled with clearance of shafts etc is really going to be trial and error
....nice idea though and worth a try if you have time on your hands.
