LCR Splitter Fitment
christhkiddy
hi ppeps just picked up my lcr splitter just after advice on how its fitted surely its wider do you need to cut any of????
Cheers in advance
Chris
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I've just ripped mine off on a squirrels head. (yes I felt bad, well unti I saw the damage the fury little %$#* had done!)
Won't be putting another on. Pain in the arse.
bbsboy
89
i cut down the 2 centre pegs, then lined it up in the middle, and attached using screws, when it came to the curve i cut small triangles out of the inside to allow it to bend then heated it with a heat gun till it fitted nicely, then trimmed off the ends, easy peasy
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Depends what look you're going for, yes they look a bit racier/deeper but more cluttered at the front, I quite prefer it a bit smoother without now.
Not to mention if you're low it will catch on everything. I measured 80mm of clearence splitter to road on mine!!
Ripped it off twice!!
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
i grounded mine today on a build up of tarmac in a carpark
was funny to look at, not funny hearing the scraping when reversing off it
its easier to use a power drill underneath the bumper if u jack it up, theres a big mounting point , right in the centre, on the bottom of the engine u can use easily. take no less than 15mins
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
From the seat dealer mate for about £16. Think they list them as Leon Cupra-R front spoiler, no doubt someone on here will have a part number. Mine usually has some in stock as they apparently get lots of Leon owners in who have smashed them off on kerbs etc
