I bought a lcr a few weeks back with a fault. When under load SOMETIMES it surges and then hessitates as soon as it does this the car then over fuels and doesnt run right tick over is lumpy but it is still drivable just costs more on fuel and isn't as smooth. Any one able to help with that or will I need to do some logs to find out ?The person I bought it of says he has replaced the n75,maf and has changes some pipe work for silicon and took the throttle body apart and cleaned that with no look..
The things that the car has had done on it when I got it was
Hybrid turbo
Stage 2 rep map (apparentyl)
Ram air filter
Cobra exhaust with decat
Since getting the car i put a 007 recirculation valve on and as of yesterday bypassed the n249 by putting a hose from the dv to the inlet and put a front mount on and since putting a front mount on yesterday I put my foot down and in 3rd it held back at around 3/4000 revs and acted as if that was it's limit and seemed bogged down now it's still running standard tip atm as I carnt find a over sized red tip! Could this be colapsing causing this to limit out as explained about or could this be something else?
Hybrid turbo
Ram air filter
