LCR - Revo STG2 logs
May 13, 2007
1,017
Denmark
Hi all,
Long story short, I think I fixed my boost leak, and I made some new logs.
Revo STG2 B9T7 - Should I advance the timing further?? Ambient temp was like 12 celcius.
Logs made from 4.th gear... shhh...
Code:
	Group A:	'112				Group B:	'020				Group C:	'118
		Temperature	Load	Bin, Bits	Bin, Bits		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Temperature	Load	Absolute Pres,
	TIME					TIME					TIME
Marker	STAMP	°C	%			STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	°C	%	 mbar
5	887,2	665	0	        	        	885,77	0	0	0	0	886,49	2520	20	0	1020
	889,18	675	0	        	        	887,85	0	0	0	0	888,51	2720	18	95,3	1620
	890,88	755	0	        	        	889,76	0	0	0	0	890,32	3440	15	79,6	2290
	892,65	825	0	        	        	891,45	0	0	0	0	892,01	4200	15	85,1	2410
	894,6	870	0	        	        	893,27	0	0	0	0	893,91	4920	17	86,3	2340
	896,55	905	0	        	        	895,24	0	0	0	0	895,95	5600	18	95,3	2220
	898,4	935	8,6	        	        	897,26	0	0	0	0	897,82	6120	21	95,3	2190
	900,12	935	13,7	        	        	898,95	0	0	0	0	899,52	6480	21	95,3	2080
	901,96	930	13,3	        	        	900,7	0	0	0	0	901,35	6800	23	95,3	2130
wild willy
2,323
Wales
The absence of any timing pull (cf's) would indicate yes but the high exhaust gas temperature concerns me. 930 degrees egt is knocking on the door of ecu protection mode by reducing injector duty cycle to cool things down.
Have you considered AEM water injection.
May 13, 2007
1,017
Denmark
Actually the EGT had my attention, but water injection isnt a subject, as I'm trying to keep the car MOT friendly... LOL
I could lower boost to 8 and raise timing to 8, but I think the timing is fairly high at the moment.
Odd thing is, it wont log over 210 g/s(My logs typically stops at 6500 rpm) over MAF and req/actual boost dont meet perfectly. To think point I have been over all silicone joins etc. -Last think could be knackered turbo housing(hot side) or the exhust manifold.
Code:
	Group A:	'115				Group B:	'003				Group C:	 Not Running
		RPM	Load	Absolute Pres,	Absolute Pres,		RPM	Mass Flow	Load	Ign, Timing
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	 g/s	%	 °BTDC	STAMP
5	913,66	1720	18,8	1000	1000	914,21	1760	9,33	10,2	23,3
	914,83	1840	82,7	1700	1050	915,47	1960	39,44	97,3	17,3
	916,1	2080	109	1860	1370	916,74	2240	59,53	100	12,8
	917,43	2480	150,4	2160	1870	918,13	2720	111,86	100	3
	918,82	3040	191,7	2300	2270	919,44	3280	128,36	100	6
	920,15	3600	191,7	2420	2340	920,76	3840	160,47	100	8,3
	921,44	4160	191,7	2450	2460	922,13	4440	174,78	100	12
	922,77	4720	191,7	2430	2360	923,47	4960	187,28	100	10,5
	924,16	5240	191,7	2380	2280	924,79	5440	197,78	100	12
	925,46	5680	185,7	2320	2160	926,04	5840	199,72	100	12,8
	926,63	6040	176,7	2270	2110	927,19	6160	202,33	99,6	13,5
	927,72	6320	164,7	2230	2070	928,29	6440	202	99,6	13,5
	928,91	6560	166,2	2220	2070	929,51	6680	202,17	99,6	15
	930,19	6800	157,9	2220	2080	930,8	6920	0	7,8	9
May 13, 2007
1,017
Denmark
Hmm... I dont know who the owner of this technical insight document for the Leon Cupra R is, but it states 950 c.
Quote:
The maximum allowable temperature for these components is 950 °C. When this value is
exceeded, the control unit intervenes and reduces the injection time until the temperature drops.
http://lee69.co.uk/Car stuff/CupraR.pdf
But if its really 920, I might lower the boost to 7 or 8. :eek:)
May 13, 2007
1,017
Denmark
I might lower the timing instead of the boost, as i have the forge big race intercooler.
Bill, do you have any suggestions as revo dealer? My mods are listing in my signature.
The blueflame are a complete system from turbo and backwards.
