cuprastu77
my remote key on my lcr when pressed once opens the drivers door like normal but when pressed twice does not unlock the rest of the car what do u think is the problem
I thought that when you pressed the key fob once all doors opened unless you have changed it via vag com to do this, I have done this but cant remember how to do it off the top of my head, have you changed the values your self through vag com or someone else?
the only way to look at this is with vag com, or if you bought your car like it and it is under warranty take it to the dealers to sort out.
just got this off ross techs web site (vag com)
if you have vag com or know someone who has vag com see if they can do this for you, sounds like someone has put the wrong number on the recoding when changing this or could be a fault with your central locking if not this.
please read >>>>>>>>>>>>>>>>>
46 - Central Convenience: -- KWP1281
Only on vehicles with power windows. VAG-COM fine. There are numerous options/ features that can be set.
Selective Unlocking:
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
So, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
