Ive just did a fault code check using the U281 Memoscanner i bought off ebay as recommended from someone off here.
Ive also just done a google search and found this site that gives fault code descriptions and probable causes that lists the faults:
http://www.volkscity.com/Files/VW GOLF 2800 V6 4MOTION 2.8 BDE Eng.pdf
Ive had the following codes for engine:
17704 P1296 - Cooling System Malfunction:
ECT Sensor, engine coolant thermostat
19534 P3078 - Throttle Control System - insufficient air flow at idle speed:
Throttle vavle housing requires cleaning, intake leak, wiring, maf sensor, TP sensor, Throttle control unit, ECM
Also on the reader it scans for SRS and ABS which found no faults and A/T which keeps coming up linking error.
What is the A/T?
Also has anyone else had the other codes above and is it something major? How much will it set me back and can it be done by a non dealer.
Thanks in advance
What is the A/T?
Thanks in advance
