LCR MK1 Fault 17704 & 19534
scarface
615
West Midlands
Ive just did a fault code check using the U281 Memoscanner i bought off ebay as recommended from someone off here.
Ive also just done a google search and found this site that gives fault code descriptions and probable causes that lists the faults:
http://www.volkscity.com/Files/VW GOLF 2800 V6 4MOTION 2.8 BDE Eng.pdf
Ive had the following codes for engine:
17704 P1296 - Cooling System Malfunction:
ECT Sensor, engine coolant thermostat
19534 P3078 - Throttle Control System - insufficient air flow at idle speed:
Throttle vavle housing requires cleaning, intake leak, wiring, maf sensor, TP sensor, Throttle control unit, ECM
Also on the reader it scans for SRS and ABS which found no faults and A/T which keeps coming up linking error.
What is the A/T?
Also has anyone else had the other codes above and is it something major? How much will it set me back and can it be done by a non dealer.
Thanks in advance
Bit more info for you mate from the RossTech Wiki page:
17704/P1296/004758 - Error in Mapped Cooling System
Possible Symptoms
  • Cold start issues
Possible Causes
  • Coolant Temperature Sensor (G62) faulty
  • Coolant Thermostat faulty
Possible Solutions
  • Check Coolant Temperature Sensor (G62)
  • Check Coolant Thermostat
Just searched the second code though and nothing is showing against it?
scarface
615
West Midlands
The coolant temprature one might be correct cos i used to have the thing beeping at me in the winter, but i scrapped the prong thing as advised on here and seemed to work fine after that.
bazk666
U281 reader...........
(n/a )
What is the A/T?
Thanks in advance
m8 this is the samething I was getting lastweekend, thanks for putting me straight Richardo smooth... A/T automatic Transmision.......... :lol: what an idiot I am........
