LCR Engine Warming Before putting foot down
alibali45
gonna play devils advocate for a moment.Personally I always let me car warm up before i floor it, but at the same time, what do the manufactures say? I am sure they would have a hard time selling a motor if they told the driver that you have to let it warm up fully and sit in you drive way with the car idling for 20-30 secs when you are finished.
i am not totally convinced that this is a total prerequisite each time i use my car, yes it does help and I can see how letting the oil heat up would help it do its job , but have the manufactures in there stress testing of these engines not have taken this into consideration
In addition would they not have fitted an oil temp guage with a warming in the first place.
I am aware of this warming up and cooling down, but the average joe is not, so how many cars are out there still going strong without this procedure ever being performed.
TBH manufacturers (in general) dont really give a toss, if you break it just means more parts and labour sales for them!! It does make a quick reference to a 2 minute cooldown after 'heavy engine load' ie thrashing in the handbook as well, SEAT obviously do care - bless 'em!
Basically it's down to common sense and knowing how things work, I've seen the result of oil becoming carbonised inside the turbo after not letting it cool down properly, result is one blown turbo.
Here, here!! Yeah ive changed a turbo for someone who'd done that, impeller ground into housing - not a pretty sight!
adam_lincs
DJ Extrodinaire...
Aug 27, 2010
106
lincs
what's all this talk about cooler (and therefore lower viscosity) oil "wearing" the turbo and other components?
thicker oil actually protects components better. (drop a ball bearing into 1cm of water (low voscosity) and then again in 1cm thick treacle (high viscosity) and which substance do you think is more likely to protect the ball bearing from touching the bottom of the container....
the reason you dont thrash an engine straight away is partly to do with getting oil into higher and more hard-to-reach places first (cams for instance), and also to do with getting the whole block heated up more evenly as opposed to the pistons being hot at top, cold at bottom, etc, which can affect clearances (piston seal etc)
also, starting a car from cold and letting it idle can damage catalytic converters.
i'd say as soon as the car goes from high-speed idle to normal low-speed idle you're good to go.
adam_lincs
DJ Extrodinaire...
Aug 27, 2010
106
lincs
also, i read somewhere else that the oil pump will run on after switching the car off (on LCR) - think is in turbo timer thread. everyone saying you dont really need one because of this...
Tuck3r
87
R.C.T.
How about the complete oposite, how damaging is it to use your car without using the turbo. i.e. short runs where the engine doesn't get warm enough for you to use the turbo?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
The water pump runs for 10mins after ignition is turned off (regardless of engine temp, pump will run even if ignition is briefly turned on without engine on a morning, for example). This does not provide much prevention against oil cooking against the shaft of the turbo, however, so should not be relied upon as an alternative for a proper cool down procedure for the best life of a turbo.
I would say same as any car - lots of short runs are not good for any motor, I'm a sucker for the old Castrol adverts for this - the majority of engine wear occurs in the first few mins of driving, when the oil (hot/cold or what) has not had time to circulate around the block so you are effectively running metal on metal for the first few seconds.
Like you say, if the run is short enough that the engine does not get warm enough to be able to 'use' the turbo, then are doing the best you can by taking it steady, but obviously, 50,000 miles of 10 thousand journeys across town is going to be worse for an engine than 2 and a half thousand 20 mile commutes.
Like everyone said, just resist the temptation to thrash it until 10 mins in - this I think is one of the best part of the trip computer.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Very silly one here guys so sorry..
Anyways, my point is, i totally forgot that Id only been driving 6 or 7 minutes from cold before putting the pedal to the metal... (the temp needle was on half, and i know its only water temp) but im worrie about the oil not being warm enough .. ive never done this before, always let the car warm up properly. could i have damaged anything? and what, if anything can this cause in the long term.???
LOL and i thought i was the only one with warm up OCD ;)
Feb 28, 2010
1,367
Southampton
Im with Traumapat on this one - i always let my car warm up & idle drops down to circa 700 before moving. then about 10 - 15 mins for oil to warm up, usually gets to 50 fairly quickly then creeps up. But is just about right before I reach the motorway :D
Then about 1-2 mins after a normal gentle drive, 5+ mins after a hard drive / track session. very heavy track session is about 10 mins and bonnet up, but thats when you cant put your hands near the wheels alone due to the heat :D
Maybe overkill - but works for me! Mighty cupras on 100k now and regular service. Its all swings and round abouts ehhh!
this is one of the reasons why i miss the mfa computer on my golf vr6
it had the engine oil temp on it, i used to keep an eye on it til it was at least reading around the 75-80degrees mark before even thinking about taking her above 3k.
would normally take around 10mins to get to this temp.
was also an effective way of keeping an eye on oil temps when giving the car a thrash.
i'm on the look out for an oil temp gauge at the moment
Feb 28, 2010
1,367
Southampton
Liquid Gauge baby - love mine!!!! oil temp plus EVERYTHING else - I now swear by it! espec as ive developed a problem, feels like a boost leak and its now telling me that I gota throttle valve pressure hose leak - so off comes the throttle body tonight and find that leaking pipe :)
I hope!
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Even a 50/60 grade engine oil is very fluid at 70-80-90 degrees C.
I personally can't see any components getting starved of oil once the oil temp has reached 70 degrees.
A good oil will always have less polymer to reach its desired viscosity grade, polymer is very sticky and thick at colder temps so this only starts been really fluid at higher temps. Oil which is blended the proper way has less polymer and a mix of different grade base oils to reach its desired viscosity grade, which results in much more lubricity/flow at lower temps.
Pyro
I just only use half throttle ;) and drive slow for a few mins
;) ang let it cool for a min or two and turn it off it's always best to let it warm up whiles driving slowly to keep the oil moving and it warms quicker like that same as cool down keep the oil circulating and if you don't let turbo kick in the it's all good :D
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
where i work i come out on a main road at 50mph and the car doesnt even get a chance to warm up! i try and make sure that when i do leave work i have plenty of space to pick up speed slowly and then drive carfully constantly until i reach home and try not to thrash it. my driving is basically like this:
start 50mph for 1 mile, then 25mph for 2 miles through town taking it easy over humps etc, then 40mph on 1 mile dual carraigeway and then 30 mph for the last mile home. i am hoping this doesnt cause too many issues for the engine.
