LCR Crash bar
Apr 24, 2007
985
W. yorkshire
This might seem a stupid question as well as a pointless one butt..
Does anyone have a picture of the crash bar that forge supply with their FMIC?
In particular the rear of it?
As im in the process of fitting my own FMIC but oviously need to modify the crash bar to fit it so was wondering what forge had done
Jonny
slightly insane monkey
Jul 5, 2005
769
South Wales
Best I can do I'm afraid...
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I had a good look at it when both were off, basically the Forge one is thinner (front to back) to allow space for the FMIC to fit behind it but infront of the radiator. I firmly believe the Forge one is a standard one modified, nothing more.
I still have my stock one if you want it?
Apr 24, 2007
985
W. yorkshire
well what my plan is...
im going to remove the bracing on the back of the standard one
and trime the top part of the bar down to match the bottom (as the bottom part is thinner)
or just 25 mm which is whats needed
then weld the bracing back on the back to creat support for the weight of the IC so i can mount it to the crash bar
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup sounds about right, as said I think this is what Forge have done.
Good luck, keep us posted.
If you want any of the info on the hoses or connectors I've got it all on email as one other member was asking for this. I have pictures and measurements for these (OD's, ID's, bend radius and lengths)
Apr 24, 2007
985
W. yorkshire
yeah that info would be good mate
from what i can make of it forge supply a 2x45 deg 2x75deg and 2x90deg
but not sure on lengths
