LCR 2008cc GT3071r Billet Build
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
I wanted to get something up in this section as people with the knowledge of BT installations will have a look in this section rather than trawling through a RR thread. I'm starting the build on my car this week / weekend. Here is a breakdown of what is happening / going in.
Block
BAM Engine Block Bored to 83mm
2.0 TFSI 92.8mm Forged Crank (Part Number 06a105021AR)
1.8 Oil Pump Drive Gear
83mm Mahle Motorsport Powerpack Pistons
Mahle Motorsport Piston Rings
Mahle Motorsport Wrist Pins
06a 1.8T Oil Squirters
DM Forged 144 x 20 Connecting Rods
ARP2000 Connecting Rod Bolts
Calico Coated Main Bearing Set
Calico Coated Rod Bearing Kit
ARP Main Bearing Stud Kit
ARP Head Bolt Kit
HEPA Metal Impellor Water Pump
Gates Performance Timing Belt
9A Manual Tensioner
Contitech Serpentine Belt
Custom Made Oil Catch Can
Overbore Master Gasket Kit
Cylinder Head
ADR Large Port Cylinder Head - Ported & Polished
New Valve Guides
Ferrea F1556P 26.9mm Intake Valves (12)
Ferrea F1554P 29.9mm Exhaust Valves (8)
Ferrea S10055 Intake Valve Spring (12)
Ferrea S10056 Exhaust Valve Springs (8)
Ferrea SL1025 Intake Spring Seat Locator (12)
Ferrea SL1026 Exhaust Spring Seat Locator (8)
Ferrea E11031 Titanium Intake Retainer (12)
Ferrea E11032 Titanium Exhaust Retainer (8)
New Valve Stem Seals
New OEM Hydrualic Lifters
Turbo
HTA GT3071r Billet Wheel
Tial Vband Turbine Housing .82A/R
Tial 38mm MV-S External Wastegate
Manifolds
Exhaust Manifold TBC
SEM Motorsport Large Port Intake Manifold
Bosch 75mm DBW Throttle Body
INA Adaptor Plate
Fueling
Bosch EV14 750cc High Impedence Injectors
Bosch 044 Fuel Pump
Cooling
Forge Motorsport Big Race Intercooler
Drivetrain
Southbend Stage 3 OFE Daily Clutch Kit + SMF
034 Machined Gearbox Linkage Bushes
I'm currently trying to source somewhere local that I can borrow and engine crane from, got a stand etc just need something to lift it out with.
westallc
132
wow going to be epic that but if you can afford all them goodies surely you can buy yourself an engine crane lol
as now your in the high hp class i can tell you now its never and easy ride lol and engine will be in out in out ;)
what have you done handling wise???
will be mental on the road well done
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
I can afford an engine crane, it's that I don't want to have to afford one :D especially if I can borrow one.
Handling wise I've got full kw coil overs and whilst the engine is out and I've got access to the subframe will do the front anti roll bar and rear too.
Looking forward to it.
I've been out there tonight stripping everything back, removed induction system, battery, coils and loom, charge pipe upper boost hoses. Going to get the front end of tomorrow bumper, cross member etc.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Does anybody know if the K04 oil and coolant lines need to be kept in order to attach the GT30 lines to the engine & coolant system?
I know the coolant feed comes from the block, oil feed from the oil filter housing, oil return into the sump but not sure on where to attach the coolant return pipe?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
the flow and returns should be to the same points as k04... the lines however wont be anything like the same.
make em up
grahams81
1,165
County Durham
Just been working out my coolant pipes James and my original turbo coolant line joins to a plastic y piece next to the cambelt cover just upstream of the Expansion tank.
Mine is a LC though, LCR maybe different i think they run a pump to keep coolant circulating round the turbo after the engine has shutdown.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Thanks for the input people, I'm sure it will make a lot more sense when I come to installing it all. Just waiting on the engine back from the builders then I can start piecing it all back in
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
HELP!
I'm in desperate need of someone who has got a scrap 1.8t head with cam caps, my engine is nearly finished but my cam cap at the cam pulley end (the double one) has gone missing and need to find one ASAP to try and get it line re-machined for the head! Help please?
