mirroreyes
Oh man more problems
The latest problem seems to be mainly when its cold and is intermittent, the idle is lumpy, when I depress the clutch, when coming to a stop the revs drop to nearly zero, or zero and cut out. It sometimes gradually gets better as it warms up, but seems to be happening more and more of late.
I've been meaning to get rid of this piece of crap (I used to love this car) for two years now but every time I come to do it, something else goes wrong (clutch last time)
I've read a few threads regarding this issue (most are for other models with different engines and there is some conflicting information) I really need help as this car is driving me mad and has cost me a fortune.
Problems to date:
leaking doors (Took the dealer 7 attempts to resolve)
loose anti roll bar mountings.
Clunky gear-change (Shift cables tightened)
2nd & 3rd Gear sycros crunching (Recon box and oil change)
Clutch collapsed and snapped the master cylinder (New clutch & cyl)
Rust through paint.
Squeaky rear seats.
Flasher unit failed.
Front headlight stopped working (Not the bulb)
Engine rattle when cold starting (Still unresolved)
Metal clanging sound when going over bumps (Still unresolved)
Noisy suspension (Sounds like worn bushes)
The radio had a spat then decided to work as normal.
Problems to date:
Rust through paint.
Squeaky rear seats.
