glad your enjoying the rear arb,i dont understand why your rear is rubbing though i had mine right down with 20mm rear spacers with no problems i did have the adjuster cups in though but still shouldnt be rubbing i dont think. mine only occasionally rubbed on the fron on fast corners with a slight bump.
I also run a higher profile tyre on the back so that must have something to do with it I'm not really bothered about it, I only have folk in the back once in a blue moon
that will be why didnt realise you ran a higher profile at the rear i always wanted to try a higher profile on mine to see if it made it more comfy,i dont suppose you can tell with it only being on the rear can you?
The back takes bumps a lot better, also makes the stance subtly different I didn't want to run the high profile on the front incase it threw the speedo out too much
