What you need mate is called a paint correction detail.
You don't have to do that though.
To get your car looking in good nick you need to start being anal with car cleaning.
Have you ever heard or the 2 bucket method?
Stay away from yellow sponges, use wash mitts, they don't hold dirt and are less abrasive.
Don't use leathers to dry your car, they're hold dirt like you wouldn't believe. Which means everytime you dry the car, you're rubbing the grit and dirt which causes very fine scratches in the lacquer.
To get rid of those small scratches or 'swirl marks' (called that because as you look at them they are in a swirling pattern).
To get rid you have 2 options. Either get some cutting compounds that take off very fine layers of the lacquer to remove the scratches.
Or get some decent detailing products, eg Autoglym super resin polish (SRP), Autoglym Intensive Tar remover (ITR) and autoglym extra gloss protection (EGP).
The polish is an extremely light cutting compound and also has fillers in to fill in the fine scratches, and remove some.
If I were you then I would just go for a good polish with some elbow grease.
The procedure:
- Wash the car using the 2 bucket method using AutoGlym bodywork shampoo conditioner (in my experience cheap triplewax products take off wax very rapidly)
- Go over the car with AG ITR which will take off pain contaminants and leave the paint work like glass.
- wash and dry the car again.
- go over the paintwork with the polish applying with a clean microfibre in circular motions.
- buff off the polish once its gone a bit cloudy with another clean microfibre.
- then do the same with AG EGP.
- then again with a good wax.
You can repeat the polish several times to get rid of the swirls then do the EGP and wax it.
I detailed my car last week so I have some information on my RR.
There is also tonnes of information on
www.detailingworld.com.
Sent from my BlackBerry 9800 using Tapatalk
