Lambda Probe Fault
Yumann
1,638
Glasgow
3 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
P1116 - 35-00 - -
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-00 - -
Unsure what this means, but I am pretty sure it is a dud lambda probe. However, which lambda probe would it be pre or post cat?
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Ive also got lambda problems mate and ive been told Blank 1 is the pre cat and blank 2 is the after cat mate. All them codes are pointing to that sensor so should be alright after thats been replaced
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Yes its the pre sensor (One on the down pipe), if it stays open circuit, most of time its knackered and needs replacing
