When logging lambda what am i actually looking out for, readings wise?
On a 4th gear run.....
3600...0.977,1.000
4040...0.961,1.000
4480...0.938,0.930
4880...0.875,0.891
5240...0.836,0.860
5600...0.844,0.852
5920...0.860,0.852
6240...0.821,0.852
6480...0.805,0.852
6720...0.836,0.852
How do i know if im running rich or lean and are results only meaningful on full throttle acceleration? What are both columns indicating?
Im sure ive read under full throttle you dont want to be seeing anything above 1.000? Is that right?
Also what are the upper limits of the CF range that you dont want to be seeing? Im getting a couple of 6.0's, is this too much timing advance?
Just for example...
5040...2.3,3.0,3.0,6.8
5240....3.0,1.8,1.8 ,6.0
5720....0.8,2.3,0.0,6.0
6000....0.8,1.5,3.0,6.0
6320....0.0,1.5,3.0,5.3
6560....0.0,1.5,3.0,5.3
Looks like cylinder 4 is doing a bit of work?
3600...0.977,1.000
4040...0.961,1.000
4480...0.938,0.930
4880...0.875,0.891
5240...0.836,0.860
5600...0.844,0.852
5920...0.860,0.852
6240...0.821,0.852
6480...0.805,0.852
6720...0.836,0.852
Just for example...
